FS Mountain Bike Suggestions
12 Jun 2005
Newcastle
Hi All. Looking to get a new mountain bike but have been out of biking for a few years now, used to have a hardtail Carrera Kraken. Looking to get a bike to improve my fitness and also get into a bit of riding down hills etc and cross country hence the need for a full suspension.
My budget is around £400, and i am not sure wether to buy new or used. Any recommendations?
You are not going to get a full suspension mountain bike that is any good for £400 and even second hand you will be pushing it.
Get a decent hard tail. You can go XC and Downhill on a hard tail and it will teach you proper technique rather than just using the boing boing in tne rear.
image.aspx
I just purchased a Voodoo Bantu 2007/8 model from Halfords for £400. The new season 2009 model is £600 so if you can find any halfords with any left I would highly recommend one.
Well i'm 6" 2 so thats why i was looking at that frame, think there shop is in the MetroCentre so will have a look after work tomorrow.
Cheers for the recommendation Izi but im after a FS.
http://www.merlincycles.co.uk/custo...ountain-bikes/commencal-normal-disc-2009.html
I just bought the bike above last month and very happy with it. If you do go for it do yourself a favour and buy the pedals linked below which are a bargain! Free P&P aswell.
http://www.merlincycles.co.uk/mountain-bike-pedals/flat-bike-pedals/wellgo-platform-pedals.html
They're just these but for half price, made in the same factory!
http://www.merlincycles.co.uk/mountain-bike-pedals/flat-bike-pedals/dmr-v-12-pedals.html
