ATi Catalyst 9.7 Released
12 Mar 2006
N.E England
As per title now availble on the main site;
AMD has delivered its first official unified WHQL certified graphics driver designed for
the Windows 7 RTM (Release To Manufacturing)
ATI Catalyst™ 9.7 delivers a superior Windows 7 experience:
Great gaming performance – superior performance compared to Windows Vista for single
GPU configurations and ATI CrossFireX™ configurations
Stability – through AMD’s WHQL certified, unified Windows 7 / Windows Vista graphics
driver
Leadership in Innovation – support for all the Windows 7 WDDM 1.1 features and AMD
ATI Catalyst features on the ATI Radeon HD 4000 Series, ATI Radeon HD 3000 Series, andATI Radeon HD 2000 Series of products
http://www.ati.com
I will be waiting to hear about the difference as I am still using Vista x64 Ultimate on my gaming machine...so let me know the score fellas :D
win 7 pwns vista anyway, I wonder if there are any performaces gains with 9-7 even for vista hmm
Yeah, I want to see benchies. All this "Win7 pawns Vista" rubbish. I want to see raw FPS increase (and not just in Fallout 3). Still, great to see Win7 being supported so well :)
They have.
ATI Driver Download Page said:
ATI Catalyst™ 9.6 Components Windows 7 (32 bit)
Note: All-in-Wonder™ boards operate with AMD Windows 7-Ready Display Drivers under the Windows 7 Operating System. However there is currently no software application which provides TV/Capture functionality for All-in-Wonder™ boards under Windows 7.
Package Includes File Size Version Date Posted Download Link
Display Driver Only 22.9MB 9.6 6/15/2009
:confused:
For any wanna be TH2G gamers, apparently these new drivers now support TH2G at 5040x1050 see here: http://www.widescreengamingforum.com/forum/viewtopic.php?t=16287&postdays=0&postorder=asc&start=0
Fixes include:
- Lack of general 5040x1050 resolution for all ATI HD series cards.
- Problem with the "DVI 4" output head not allowing 4320x900 and 5040x1050 mode. (Now both heads of ATI boards will behave the same and will offer all modes properly)
- Fix to enable widemodes with multi-board crossfire configurations
- Fix to enable widemodes with X2 series ATI cards
- and a big final item: increased timing support for 5040x1050 mode with ATI cards to allow 5040x1050@59Hz in all scenarios. (This has been tested with most panels previously found not to sync with nVidia GPUs at 57Hz. Those panels now DO sync correctly at 59Hz).
To enable these fixes, users will simply need to install ATI's 9.7 Catalyst, and then install Matrox's 2.05 Powerdesk:
http://www.matrox.com/graphics/en/support/gxm/software/
the powerstrip method mentioned above should not be necessary. (Cataylst 9.6 also has a few of the fixes already, but not everything. So feel free to use it for trial & error in the meantime at your own discretion).
