Wish my E39 had a bigger fuel tank, 70 litres isn't enough really - I hate visiting petrol stations![]()
It's quite a large car though...it's a fairly standard sized tank for this type of car, the E65/66 BMW 7 series has an 88 litre tank, as does a W220 Mercedes S-Class. Driven sensibly though, it doesn't mean it really uses anymore fuel than say my old ST220 did (actually slightly less on a good run it seems), it just means I'm in the fuel station a whole lot less, as that only had a 58 litre tank, which is fine for the typical 2.0 Mondeo, but the 3.0 V6 ST220 could empty it mighty fast.
But you must get around 40mpg all the time?
That could be other things though and car age / wear related, more oil being burnt than last year, cat not doing as good a job, sensors letting it run slightly rich.
My tank is supposed to be 50L but I hit the red light after 40 litres giving the car a 10L reserve. I daren't test that much though, but I've done 30 miles after the light when I was miles away from a fill up.
Shocked, thats quite a large tank by anyones standards!
no in my experience.
about a quarter of a tank before the car is back to normal after using 95 ron
with regard to adaptation, any ecu with knock control is always looking to advance ignition (within preset parameters), for economy reasons etc
