Mountain mods Twice7
19 Aug 2007
i like that a lot...thanks a bunch just as i get my rig almost finished im now thinking of getting one of these :(
The site does show a price in Euros as well as US dollars, not sure if this means they have a European warehouse/centre whatever though. I have found one UK supplier but they did not have that particular Twice7 case. They only had the Windowed version, not the fully acrylic sided one I want...Tried contacting them but got no response :( Forget the webby now..If I find will linky.
I think the ship them in from the us. You can order from mm and they will ship it to you also.
Surely if Overclokcers don't sell them then they aren't really competitors...apart from other stuff they may happen to sell. Unless OC want to start stocking them :P
Just cant link to other shops, end of... direct competitors or otherwise.
But its better to order direct I think, then you get the full choice of options for each case. Buying one from another retailer just means you get one sombody else has specced and you'll have to make compramises :(
I hate square boxes like that
Yeah.
Could fit well for example into middle of AV equipment on some cupboard but for normal use that fat design just wastes desk/floor space.
Better to not take that case to EMC testing...
