svchost.exe
N$X
N$X
17 May 2004
West Yorkshire
according to my task manager the above application is running 5 times, should i be concerned?
my internet is running sooooo slow, constant time outs.
thanks.
i am trying to find the problem that causes timeouts. it happens on ie, firefox and opera.
my torrents download fine.
msn stays logged in.
i can play cs without getting disconnected.
skype works.
it just dont like surfing. i am trying to save myself a full format.
i have run my avira, malwarebytes and spybot.
even posting here, i have to click resend about 6-10 times.
any other suggestions?
it ok - you dont need to worry about it -- I looked up my own and I dont have svchost.exe cos I switched off "Microsoft Client" and "printer file sharing" in Network Sharing Center and enabled "Private Browsing" in Fx 3.5.1 to stop from collect cookie,history,etc.. it keep clean out everytime
skype works.
try setting up a machine in virtualbox and see if it does the same thing
what isp are you with and what router do you have?
I used Freeola with "Family" ISP broadband and using Netgear DG834v3 and already updated fireware version -- I just has been reformatted and reinstalled 2 weeks ago to get refresh..
also Ive enabled blocked 3rd party cookie in Firefox 3 (both in Option from tool menu and in cookiesafe) -- it not recommend to tick and keep use 3rd party cookie all time, just uncheck and only if any site need to open from 3rd party cookie then tick for temp (short time).
