- 31 May 2006
- West London
How do you mean m8? Like red plugs should have red shrink and black plugs black shrink etc?
I think the the white braid / white heatshrink with the red plugs look really good - much better that the normal black/black/red.
Reminds me of Geisha makeup or Mondrian paintings - very striking.
Was the hue of the blue heatshrink that I don't like againest both the black plugs and dark blue braid.
Just think that black heatshrink might 'hide' the joint instead of advertise it. But as I said above this is
due to seeing it against a white background and out of context.
Edit: (w33bo's pic's below)
I'm just looking at the mobo and braiding next to each other on screen. The heatshrink matches the SATA
and Ram/PCI-e slots nicely and the Braid is more in keeping with the pcb/heatsinks.
So when installed it should complement the mobo perfectly
I do still think the shrink to match/complement the plug is underused as an idea, and that the light blue shrink 'jumps out'
but as every your choice is spot on. Sorry for doubting you.
which will be sprayed up white to match the other three. I can then finally get cracking with the install
, oh well they are still good fans, great airflow vs noise ratio and I can paint them
