Nice bikes
I've had dozens of different bikes over the years and now have a 2007 Hornet 600 and will be keepng this one for a while now.
Nice hornet, i cant work out wether i like these or bandits more.
Nice bikes
Hornets are both more powerful and lighter than bandits, with less budget components. I like the look better too, but that would be up to the individual.
As quoted .. Finish and fit is superior on Hornets.. Lighter faster more power and imho a better overal package .
If not cared for Bandits/SV will melt infront of yer eyes (more so on sv) .
If going for a hornet (older model) get a extnded front mudguard to keep the crap of the pipes... End can as the original weighs the same as a small planet and a screen and upgraded headlight bulb .
Persil
Older hornets also use the excellent CBR engine, detuned a tad though.
The newer ones like mine use the new CBR 600 RR engine![]()
I was told the Yamaha Fazer was like that it used the R6 engine but was detuned.
Not sure how true that is, was told by local bike stockist but hes full of wind and ****
Most manfacturers retune their engines for their other models. The fazed does indeed use the R6 engine and it shows when you ride it - you have to rev the hell out of it to make progress.
Even the ER6 and Versys twin is basically the ZX12r engine lopped in half
 and trying out a new motoGP style mud guard I quite like it. off too pick up trailer soon then im off oop north
	Looks mentalist Fireskull, your gonna have some serious fun!
 just different kind
