Excellent - looking forward to smooshing yaPoooookkkiiiieeeeeeeeeee!!!!!
I havent been on much lately myself been busy busy busy
But all the oldies are still about playin regularly, link, defrag, dingle, lag, midnight, fish, hippo, kearney etc etc etc etc
Myself and cat will be back to regular play soon once shes gota pc up and runnin which is in progress atm![]()
.: OcUK 3 Updated :.
As we have so many servers I thought I'd set this one to automaticly run cevolink when it is joined in versus mode. To differentiate it from the others I changed the search key to ocuklink. Changes that Cevolink makes:
-Players gain control of the tank quicker from the AI.
-Tanks forced to spawn on levels 2,3,4
-Tank burn time increased. They take longer to die from being set on fire.
-Slight Tank spawn variation added.
-Witches forced to spawn on 1 (but are more likely to appear on 2,3,4).
-No medpacks outside safe room, just pills.
-No Mercy: 4 and Blood Harvest: 4 now only have 1.2 difficulty modifier when points are awarded at the end.
-Tanks and witches should nolonger spawn as soon as the safe room door is opened.
If this server proves to become popular enough I'll make the changes on ocuk 4 and give it the same search key as well.
Will also be working on improving Link's Hard config so that it's just hard, not impossible as well as a professional config (sets difficulty level harder than expert in coop)![]()
This is the best thing ever, and I wouldn't be adverse to having more of the servers with it automatically on! It worked flawlessly yesterday.
Cheers for the servers and all the work you do into getting them running right dude. It's appreciated!
(Not a Kitten)
How the...?!Infected killed
70,856![]()
Shots Kills Accuracy Headshots
Assault Rifle 12,269 5,177 (46.68%) 98% 14%
Assault Rifle 1,825 963 (22.76%) 100% 18%
My M4 accuracy is apparently 100% too. The stats are definitely buggy.
I'd say it's definitely buggy. I know for a fact that when I'm running about a map with the assault rifle, I'll let off a burst from the hip at zombies 20 feet away and occasionally spray a couple past them.... or when they're miles away and I try to pick them off (and mine also says 100%).Dont be so shocked . Most of the time your shooting slow moving zombies at close range
Totally different to say cs or bf2 stats
Carl
Updates to Left 4 Dead have been released. The updates will be applied automatically when your Steam client is restarted. The specific changes include:
Left 4 Dead
Fixed problem with add-on installer failing to install add-ons properly on some versions of Windows
Transition screen now shows campaign and map names for add-on campaigns
Bug fixes and enhancements for Novint Falcon controller
You lot have probably played it to death, but I'm really keen to get some decent Survival games going, seeing as I missed the original party. Anyone else up for it?
