*** PSU Deal! In Stock now! ***
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
OCZ ModXStream 780W SLI Ready Modular Power Supply
The OCZ ModXStream is designed to offer consumers a combination of OCZ’s legendary PSU architecture and an efficient modular cable management system. Available in 780W, this high efficiency ModXStream offers the industry’s highest performing modular power supply on the market.
As a gamer or case modder, modular cabling is a necessity when building a cool and orderly system. To optimize airflow and eliminate cable mazes, the ModXStream power supply is equipped with EZMod technology to allow complete customization of your power system by utilizing only the cables you require.
The ModXStream was engineered to be the quietest PSU available so gamers can hear their games and not their PC. Kept ultra-cool with a load-controlled 120mm fan, the powerful ModXStream still remains virtually silent and supremely cool even at peak loads.
Next generation platforms and high performance graphics cards are essential to modern gamers and enthusiasts. Complete with 2 PCI-Express cables and six serial ATA connectors, the rock solid ModXStream is built to provide sufficient output to power demanding GPU and setups. With a sustained output of 780W and four +12V rails to provide uniform distribution of power, the ModXStream is the superlative solution for and driving today's higher end systems.
All OCZ ModXStream power supplies come backed with an industry-leading three year OCZ PowerSwap Warranty for the ultimate peace of mind.
- OCZ PowerWhisper Technology
- Internal 120mm fan
- Blue LEDs
- Connectors: 1 x 20+4-pin ATX, 1 x 4+4-pin CPU (supports double CPUs/supplies stable voltage) & 2 x 6-pin PCI-E
- Modular Connectors: 1 x 4+4-pin CPU, 2 x 6-pin PCI-E, 6 x SATA, 6 x Peripheral & 3 x Floppy
- 3 year warranty backed by OCZ's exclusive PowerSwap™ Warranty replacement program. No more endless return-for-repair loops!
Only £59.98 inc VAT.
BUY NOW
Blue's all the rage. Personally I prefer green, but the best raves have blue lasers - they're the most expensive, so a rave crew with blue lasers is truly dedicated.
OCZ PSU's are very reliable. The ModXStream range has a lower fault return rate than the Corsair :) And the Corsair is very low.
Finally for the first time ever i hold off buying a pc part in the hope a good deal appears - and it does\o/
I usually hold off and nothing changes or buy it and it does :(
Its got good reviews too.
But Im sure I saw this for even cheaper on OCUK itself a couple of days ago? I think it was £57 yesterday or the day before.
Im wonderin if theres any point to this if you buy a GPU with needs 2 PCIE power ins though. This has more than enough wattage to drive a 1gb 4870 crossfire set up, but it only has 2 PCIE cables whereas you need 4 for crossfire.
Is there a fix?
Sorry to bump this thread, but is this a temporary deal, or will you continue to have stock for this product? I ask because not many other places seem to sell the PSU, and it'll be a few months before I buy a new PC.
Is there a fix?
Its got 4x PCI-e 6 pin leads, in the description it says 2 are hard wired in the psu and 2 are modular
Tis a lie.
http://www.virtual-hideout.net/reviews/OCZ_ModXStream_780w/index.shtml said:
Although this is a modular power supply, it's not 100% modular. You have a few cables hard-wired to the unit itself and can not be removed. Those cables are the main ATX 20/24 pin cable, a 4pin/8pin CPU power cable and a single PCI-e cable (an addition PCI-e cable is included in the modular cables should you run SLI or Crossfire).
This is why I never trust descriptions from online sites ;)
