- 24 Jun 2007
- Landan.
I'm trying to implement the network shown in this thread (though things have moved on since then), and want to use the DG834G as a simple modem that feeds my Linksys WRT54GL (with DD-WRT installed).
Everything works great, however the Netgear only syncs at 18Mb/800k whereas my O2 box syncs at 22Mb/1.3Mb.
Does anyone know anything I can try to attain a higher sync speed? Or is the Netgear just too old now? It's a v2 btw
I'm using the following settings:
* Encapsulation: RFC1483 Bridged
* Multiplexing: LLC
* QOS Type: UBR
* Autodetect: Disable
* VPI: 0
* VCI: 101
* DSL Modulation: ADSL2+
* MTU: Manual
* MTU Size: 1500
(Shamelessly stolen from someone else)
Alternatively, does anyone know how I can get the O2 router to just work as a modem?
Thanks in advance
* Multiplexing: LLC
* QOS Type: UBR
* VPI: 0
* VCI: 101
* MTU: Manual
* MTU Size: 1500
Thanks in advance
