The pen thing you're talking about is the Z pen... very good concept but as i said the ink refills are expensive and a bitch to get hold of.
After recalling what my bro took to uni i think the existing pc won't be a problem after all. - i will have a look at the matx cases though, and thanks for your help on this, despite me being stupidly undesisive
Amp34- i think what you're saying is very true, especially about the libary. I'm hoping to do mechanical engineering, so i don't know whether there are any specialist programs which require a hefty pc, but that is the odd thing about netbooks- where can you take a netbook that you can't take a laptop.
- One thing im going to really look into is some sort of digitalisation of my notes. My organisation skills are terrible, and i really do need something to save all the notes i make, digitally. I'm going to have a look at some cheap tablets, and also touch screen laptops. - it sounds excessive, however it would save me a lot of space in lectures if i just have to wright on the screen, rather than having the laptop out with another periphial.
- What sort of spec a laptop would you suggest is powerful enough ?..
. A third option I guess you could do is to scan in your pages at the end of the day into PDF files?
