Long press the ?123 key, select input method, and then select touch input..............fix it?
Ah nice one
Looks good
- note though that "calibration" feature force closes, I assume this is Hero only though.Just tried the HTC Sense keyboard file but am I supposed to get more options other than QWERTY, Phone Keypad and Compact QWERTY?
Blimey! how many more do you want?? that's it i'm afraid but i can't think what other style you would need and it's two more than the original
A friend mailed me this - its an awesome keyboard for android:
http://androinica.com/2009/08/10/touchpal-keyboard-enhances-cupcake-keyboard-experience-sort-of/
Well I could be wrong but I thought they were already there before I installed this app?
Definitely not mate
Epic Fail.
I JUST realised that when I got the phone talking to the Vodafone person on the line I wanted an 8GB SD micro card and they said they had none in stock but if I took the phone into a Vodafone store they could give me one at no cost.
Reckon the store will still honour this as I forgot all about it?![]()
Jus download it via astro on your magic surely? even on 2g it'll only take 10 mins.
Is there a way to properly quit an app when you're done using it? At the moment, if I read a text, use the browser, check my emails and calendar, then all those apps carry on running in the background until I manually close them with taskiller...
how do i connect my phone to my pc? ive got the lead etc and press 'mount' to connect it and it doesnt work. the drive appears in my computer but i cant access it..
