20 would be perfect with better AI...
ps3ud0
Can you do balances for each month mate?
And do the end balance be it your in the green or red carry over to the next month?
3GS version has more cars on screen. Any other differences?
*Edit Note to self. Check to see if there are any more pages to a thread before posting.
Technically it can - but the £5.99 app is the same one as the one on 3G so only 6 cars for now - great game though - Im just too crap at using the motion controls...
ps3ud0
myNZB 59p - Great app for controlling Sabnzbd+, also allows for searching Newzbin/TV NZB for downloads and adds them to your queue directly. Very cool.
MPC Web Interface (Free) - Set this up by downloading an iPhone web interface layout and allowing MPC to broadcast over your local host, basic but it allows you to browse your PC and start watching files from there, also has standard playback controls and allows you to skip to a certain point in whatever you are watching. It works in Safari so I have it set as a home screen button.
The combination of these two apps mean I no longer have to get up and go on my PC to change to another TV show/start downloads manually.(I watch movies/tv shows via the plasma my PC is hooked up to)
Edit; This is the web interface I use for MPC
Can I ask,
Are you actually downloading the NZB to the Iphone and Iphone is downloading over your wireless connection? to your PC?
I use Newsleecher and Newzbin ans I am keen to implement a solution where I can download the nzb via Iphone and place that on the PC so Newsleecher can pick it up and start the download (This last part I believe Newsleecher can do out of the box)
