I know the water temperature tends to be nearly uniform through a loop, so please don't tell me this.
Is the pressure through the loop also uniform? Since there is generally a reservoir involved I suspect it is not, and will be at a higher pressure closer to the outlet of the pump than partway through the loop. However it is quite possible that it is all the same pressure and I've just missed the point somewhere.
Reason for asking is that some waterblocks are pressure dependent, so putting my ek supreme immediately after a pump would be better than just minimising tubing length.
Cheers
(if interested, the actual motivation for the question is trying to work out where in a loop to put a second ddc. I'm inclined towards just before the cpu, suspended between an sli block and the processor. However it may make more sense to put it just after the other ddc)
Cheers
