- 18 Oct 2002
- Aranyaprathet, Thailand
there is only one place where water velocity is important but it is a crucially important place and that is in the block. The great sea-change in water-cooling was the discovery by Cathar that high-speed turbulent water impacting directly over the cpu broke down the water's innate surface tension to remove the hot water-layer that builds up in the older-style maze-type blocks. This is why all modern cpu blocks use inlets directly over the die's centre.
This is why it is generally a good idea to have the cpu block as soon after the pump as possible as this is where the greatest pressure is which helps overcome the extremely restrictive nature of impingement blocks. The more restriction within the overall system, the less pressure the pump is able to create and the overall speed of the loop is slowed down.
This is simple common sense. Everything in the loop adds restriction:
the tubing itself
the blocks
the radiator
every slight curve in the tubing
every barb
The more of those you have, the greater the impact on the ability of the pump to push the water and the slower the water must go.
Now the impact of all those little curves may be minimal but please don't say they're beneficial!
the tubing itself
the blocks
the radiator
every barb
