By using the software, you accept these terms. If you do not accept them, do not use the software. Instead, contact the manufacturer or installer to determine their return policy for a refund or credit.
As described below, using the software also operates as your consent to the transmission of certain computer information during activation, validation and for Internet-based services.
If you comply with these license terms, you have the rights below for each license you acquire.
1. OVERVIEW.
- Software. The software includes desktop operating system software. This software does not include Windows Live services. Windows Live is a service available from Microsoft under a separate agreement.
- License Model. The software is licensed on a per copy per device basis.
- Edition Specific Rights. See the Additional License Terms sections at the end of this agreement for license terms that apply to specific editions of the software.
2. INSTALLATION AND USE RIGHTS. The software license is permanently assigned to the device with which you acquired the software. That device is the “licensed device.” A hardware partition is considered to be a separate device.
- Licensed Device. You may install one copy of the software on the licensed device. You may use the software on up to two processors on that device at one time. You may not use the software on any other device.
- Number of Users. Except as provided in the Device Connections (all editions), Remote Access Technologies (Home Basic and Home Premium editions) and Other Access Technologies (Ultimate edition) sections below, only one user may use the software at a time.
- Alternative Versions. The software may include more than one version, such as 32-bit and 64-bit. You may use only one version at one time. If manufacturer or installer provides you with a one-time selection between language versions, you may use only the one language version you select.
