mine is on it's second RMA for this issue.
Gigabyte EX58 UD5
6 Gig Patriot Viper DDR3 1280
Intel Core i7 DO
Seasonic M12D 850 Watt Modular PS
I have those items out of the case with the CPU fan and a case fan connected. I've tried every stick of Ram, no Ram in every socket - No joy. All that hapens is the fans twitch, then nothing.
Did I read somewhere that there is a compatibillity promlem with Seasonic and Gigabyte?
Anyhow what can I try now? It has booted on a couple occasions, but not consistantly.
Edit: 24 and 8 pin power leads are connected.
Sorry, but you're not going to get very far with no graphics card attached. It's probably bleeping (three short bleeps and one long bleep), but you'd never know because you have no speaker.
Absolute bear minimum required to get a PC to boot;
1 motherboard with 4/8 and 20/24 pin connections to PSU
1 CPU
1 stick RAM
1 GPU
Without that you'll not get anywhere. And a speaker is your No. 1 friend when it comes to diagnosing a no-boot.
And building PCs while drinking is a sure-fire way to FUBAR the whole thing.
I'm not entirely sure this isn't a wind-up/troll thread.
He doesn't need a speaker, the board has an LED with a hex readout of where it is in POSTing. Regardless, this specific PSU will power the board for a split second - half a click on the fans then nothing, it will then need to be powered down completely at the wall socket to discharge the caps before another attempt. As the thread linked states, it appears to be an known issue with this combination (ie Seasonic acknowledge it). It's nothing to do with ram, or graphics cards, or fans.
You do not need a graphics card to enable a system to boot up or not.
You could even make the system turn on with no RAM, yes it wouldn't boot, but it would stay on. Which is a lot more than it is doing now.![]()
I have that board too and the LED Poster is useless for BOOT diagnostics. It certainly tells you when in the BOOT cycle the system has stopped, but the speaker tells you what's stopping the BOOT.
Do you have this PSU? No. There isn't any power to make the speaker squeak, because the PSU has shut down.
Because it happens to a relatively small number of people, and appears to have been resolved with newer models of the psu anyway?i wonder, why OcUK dnt inform ppl abt this prob,????
WJA96 vs Delvis will be neatly solved as soon as you start using the term POST instead of boot where appropriate. I'm sure you both know this.
