[OcUK Staff Builds] rjkoneill's TJ07
rjk
rjk
OcUK Staff
8 Aug 2007
LINK TO LATEST REVISION
heres a few pictures that should highlight bits and bobs I am doing on my latest system
special thanks:
Yewen for his assistance in component selection, calling me a hardware snob and telling me when i am spending too much!
The OcUK tech team for their input, ideas and general banter :D
Ducky_Spud for sorting me out with the screws i needed for my CPU block
hopefully it should inspire :)
Component List
Case
Silverstone TJ07B-W
4X Gelid Silent 120mm Fans
2X Gelid Silent 92mm Fans
System
Intel Core I7 Gulftown Processor
Asus Rampage II Extreme Motherboard
OCZ BLADE 2000MHz Memory
2X XFX XXX 1GHz ATI RADEON HD 4890 Graphics Cards - Removed
Powercolor ATI Radeon HD 5870 LCS - Removed
XFX ATI Radeon HD 5870 - Removed
Asus Nvidia GeForce GTX 480
Intel X25-M Mainstream 160GB Solid State Hard Drive
Creative Sound Blaster X-Fi Titanium - Fatal1ty Professional Series 7.1 Sound Card - Removed
Asus Xonar D2X 7.1 PCI-Express Sound Card
Corsair HX 850W Power Supply
Watercooling
EK Supreme CPU Block
EK ASUS X58 Mosfet Kit
Koolance MBASR2E-V2 NB/SB Block
EK FC-480 Nickel Acetal Waterblock - Removed
EK FC-480 Nickel Plexi Waterblock
EK FC-480 Black Backplate - Removed
EK FC-480 Nickel Backplate
2X EK FC4890 CF - Nickel-Plated GPU Blocks - Removed
2X Laing DDC-1Plus MCP355 12V Pumps - Removed
2X EK-DDC X-TOP V2 - G1/4 White Acetal Pump Tops - Removed
Swiftech Laing D5 Vario MCP655 12V DC Pump
Bitspower D5 Matt Black Mod Kit
Bitspower D5 V2 Pump Top
EK Multioption Reservoir 250 rev.1 - Removed
EK Multioption Reservoir 250 rev.2
ThermoChill PA120.4 Quad - 480 (15mm)
Thermochill PA120.2 Dual - 240 (15mm)
4X Meters XSPC 7/16" ID - 5/8" OD White Hose
2x Litre Nanoxia Hyperzero Coolant Clear - Removed
2X Litre FluidXP Nano Fluid - White
Bitspower
20X Bitspower Black Sparkle G1/4" High Flow 7/16" ID 5/8" OD Compression Fittings
4X Bitspower Black Sparkle 45 degree Rotary G 1/4 adapter
1X Bitspower Black Sparkle G1/4 - 90 Degree Rotary Adapter
2X Bitspower Black Sparkle G 1/4 - 90 Degree Dual Rotary Adapter
6X Bitspower Black Sparkle G1/4" Stop Fitting
1X Bitspower Black Sparkle D-Plug Set NORMAL
Mods
240mm Radiator Stand
480mm Quad Radiator Stand
30X Meter 4mm Black Cable Braid
2.5X Meter Black 2:1 Heatshrink
Sunbeam Multi Fan Power Port
Tinted Side panel Window
Tinted Roof panel Window
MurderMod Luminous Panel - maybe one day - if they ever send it to me
Looking good so far! You putting 2 rads in the bottom? Is there enough room for the tubing to curve round if you get me? Or will you be using some 90 degree fittings?
And are those Bitspower fittings from OCUK? Hope you do start stocking them soon, well want a few for my loop haha
thanks for the kind words guys
hope it doesnt dissapoint
there will be a few more updated pictures soon, as and when progress is made
OcUK is really busy at the moment so it means i am exhausted when i get back from work, thinking of having a couple of days off to concentrate on my own system
Ducky, i had the stop fittings and angled fittings a while back but the compression fittings [7/16] are all from ocuk
the full range is expected on the site soon, i know Yewen is working very hard to get the products listed for you guys
there will indeed be two rads in the bottom as the sketchup suggests
im going for one big epic loop :eek:
Carefull those pumps dont over heat if you are mounting them directly to that foam mate. I lost my first 2 for mounting against foam for try and keep them quiet!
i know - im thinking of putting them ontop of the riser mounts and stabilising them with rubber standoffs
i have them modded to 18w now
will see in time
im going to have to get some of those bitspower connectors :>)
has anyone used the ghost compression fittings?
Ive seen them, the see through coloured plastic ones? I never really trusted them, the photos of them look like they'd easily crack if you knocked them. However, they surely wouldnt sell them if they were that weak, they must be alright lol
Looks good, do you get a discount? Because i really can't imagine spending so much on that chipset block. Also, why did you go for a full cover block over a GPU block and VRAM heatsinks? Looking good though, can't wait to see it finished.
i just like hardware
i will not discuss the financial side of the build
the chipset block was imported from holland as they were the only stockists i could find
full cover GPU blocks look 100% better than core cover blocks, thats why i chose them
looks great so far m8, will look forward to an update soon :)
edit: can i ask what fans they are on the top and rear?
