Hey all,
I really need some help! Literally at my witts end, and have no clue what's going wrong.
I recently upgraded my computer, and since have had problems with it freezing up. When it freezes nothing works, mouse/ keyboard totally unresponsive. Only way to get it functioning again is to power off completely by the on/off switch (or power button).
Have tried format and reinstall.
Format and installing newest drivers by hand (incase it was a dodgy driver being auto-updated).
Switching HDD's.
Switching the Ram for some I know is good (4 x 1GB sticks, and then 2x2GB sticks using both sets of slots).
Have tried switching to a different PSU (was also 800w, as I dont have a larger one).
Ran Memtest for 24hrs without any errors.
I had wondered if possibly it was a heat related problem but after a little extra cable management and reducing it considerably decided it's likely not (will list temps just incase I'm wrong about this).
Motherboard - 35C
CPU - 33C (Highest Core 42C)
SPP - 53C
MCP - 56C
GPU1 - 42C
GPU2 - 45C
These are idle, thought the freeze seems to randomly happen wether I'm busy doing something or have just booted the comp then left it alone idling for a while - which leads me to believe its nothing to do with overheating.
EDIT: Those temps under load as promised:
Mobo - 48C
CPU - 53C (Highest core was 61C)
SPP - 60C
MCP - 65C
GPU1 - 63C
GPU2 - 66C
Spec:
- Vista 64 Home Premium
- Asus P5N-T Deluxe
- Core 2 Quad Q9550
- 2 x BFG GeForce GTX 275 OC2 896MB GDDR3 PCI-Express Graphics Card (SLi)
- 2 x Kingston HyperX 4GB (2x2GB) DDR2 6400C4 800MHz Dual Channel (8GB in total)
- 2 x 500Gig Samsung Spinpoint HDD
- BFG 800W PSU
Is there a known conflict with any of these parts?
Really need some suggestions for some stuff to try, really need to find out if something is faulty so I can return it.
Edit:
Just wondering could my PSU be too small at 800W for what is in the system at the moment? And if it was could it cause this problem?
Switching HDD's.
Motherboard - 35C
SPP - 53C
MCP - 56C
GPU1 - 42C
GPU2 - 45C
Mobo - 48C
SPP - 60C
MCP - 65C
GPU1 - 63C
GPU2 - 66C
Spec:
- Asus P5N-T Deluxe
- Core 2 Quad Q9550
- BFG 800W PSU
Edit:
