Available Graphics Memory showing 3838MB - Can it be reduced?
19 Dec 2003
Grimsby, UK
Just wondering, in games the Total Available Memory shows as 3838MB, my graphics card has 2048MB available anyway so is their anyway I can drop the shared system memory to 0? or is it neccesary?
Buying a single-GPU card with over 1gb is a bit of a waste unless you're running at 2560x1600 yes.
Ahh got a reason for that, I run 3 EverQuests at once on one PC, I used to run out of memory for my X1900XTX 512MB & 8800GTX 768MB then the screen polygons etc would start turning white due to loss of memory.
I got a good deal on the 2048MB as opposed to the 1024MB card anyway, cost me £16 extra. :)
So basically the shared system memory isnt dedicated video memory is it? it's just as it's disposle if it was required, thanks okay then I just thought it was totally committed to graphics memory.
Cool thanks for the info people, I've just read a document on the Microsoft page, cheers to "Broken Hope" for the original link.
Shared system memory is a portion of the system memory that can be used by the graphics subsystem when needed.
For discrete graphics adapters, this type of memory is often referred to as “non-local video memory”—that is, far from the GPU.
The shared memory is available to other subsystems or non-graphics applications when it is not being used by the graphics subsystem.
Thus, it is never guaranteed to be available for graphics because it could already be in use.
http://download.microsoft.com/download/9/c/5/9c5b2167-8017-4bae-9fde-d599bac8184a/GraphicsMemory.doc
