Permabanned
- 8 Feb 2004
Have you considered that it may be because of speaker positioning and or room acosutics as to why you are not satisfied with the sound? Just a though......
My dealer suggested the Chord over the NACA5?
I would not classify your source as being particularly bad at all. Hey I still use a heavily modded £12 Marantz CD-63, and found that changing speakers and the associated amp make much larger differences to the sound. Then comes poisitioning of course, but you already know that.
So would you guys agree with my dealer that i would be hard pressed to find better than my current amps for my price bracket?
Contrary to common belief and what Mr_S said, I actually haven't found Naim to be all that foot tapping !!(Shock horror..I will will be lynched by the Naimies !). For me it was all detail and vice like grip, good for percussion based music etc. BUT it never "flowed".... always had like a "staccato" effect.
Except when I heard the 555 PSU setup on the CD transports, which was the best they could offer. Then it sounded "normal" to me, and inline with what I was use to....... I remember once standing at the Linn/Naim crossroads.....Naim = "Hi-Fi", Linn = "Music"..... I'll get my coat![]()
Having just said that, spending 800 on an amp to go with an old Arcam CD player sounds a bit mad to me!
Dave
Coat? More like your pipe and slippers (to go with your Linn!)![]()
But the OP probably didn't spend £800 to buy a 112x/150x. They're quite new models, so he might have paid full price for them, meaning close on £1600.
