To expand on what I said earlier MrLOL you really do need to swap the rear too. To work out the braking force a brake has you use the following equation.
Braking Force = effective pad radius x clamping force x Mu
Where Mu is the coefficient of friction of the pad. So as you can see it is a linear relationship between braking force and the coefficient of friction for the brake pad. So say like if you double your coefficient of friction, you double the braking force. Now a good OE level pad is around 0.4-0.45, whereas the yellowstuffs you have put on is 0.6.
So to put this into context for you, say like the standard braking bias is 60% front, 40% rear this will be altered to be more front biased. And that your standard pads are 0.45, or 75% of the yellows.
If for example as standard the front brakes do 600N force whilst the rears do 400N force. Now the change in Mu will alter the front brakes to 800N whilst the rears are 400N still. This means the new brake bias is 67% front, 33% rear. This really is not optimal as at the point of the front wheels locking the rears will be doing less braking than compared to the original brake bias. So to keep the manufacturers balance I suggest yellows on the rear. Wow this post has got long, I didn't mean to write so much, got a bit carried away.
