Has you board got a SODIMM card to enable SLI ? I had a ***** of a time once and I found out (chance) the SODIMM card was one of the problems.
Yes i have a little card on the MB i need to switch around so its 8x and not 16x.I doubt that is the problem though if furmark and unigine work fine.With crysis and latest patch i get around the same performance as i do with one card.Tried various drivers for both my MB and graphics card,different bios,different OS win xp and windows 7,different sli performance modes etc.Here is crysis benchmark with SLI...i get around about the same with just one card,its much lower than i should be getting.And like i said its patched up to 1.2
27/08/2009 23:34:36 - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1920x1080, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 52.56s, Average FPS: 38.05
Min FPS: 18.77 at frame 151, Max FPS: 54.95 at frame 1639
Average Tri/Sec: -23305628, Tri/Frame: -612477
Recorded/Played Tris ratio: -1.50
!TimeDemo Run 1 Finished.
Play Time: 46.95s, Average FPS: 42.60
Min FPS: 18.77 at frame 151, Max FPS: 61.41 at frame 90
Average Tri/Sec: -26032246, Tri/Frame: -611074
!TimeDemo Run 2 Finished.
Play Time: 46.32s, Average FPS: 43.18
Average Tri/Sec: -26351814, Tri/Frame: -610288
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1920x1080 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 42.89
