Virtualbox - Transfering Files
31 Jan 2007
Hello,
I use Virtualbox a lot for testing apps and stuff.
I used to use MS Virtual PC whcih allowed you to drag and drop files from the host OS to the guest OS but it seems that Virtualbox will not let you do this.
How can I trasnfer files quickly and easily from the host OS to the guest one?
Could someone post up some easy to follow steps please?
Thanks
Regards,
Neil
I'm not aware of any drag & drop feature in virtualbox either, so the way I do it is set up a share on either OS and map it to the other. This gives me a shared area to easily move files between the two. I usually create the share on the guest OS.
I always find this a pain to do with the default NAT setting, so in the virtualbox network settings for the guest OS change the "attached to" setting to "bridged adapter". This will make the guest OS get an IP address from your usual DHCP server. Once you know this IP address and create your share, you should be able to just map the drive to your host OS with \\<guest_ip>\<share_name>
Er, couldn't you just shutdown the VM and setup a shared folder in the settings of the vm?
Yes, just create a (permanent) shared folder in the VM to point to host folder and map a drive in the guest to point to it (will be something like \\vboxsvr\files)
Another option is to setup some shared folders inside virtualbox:
If you're testing out viruses etc then obviously don't give VB write access to folders like downloads to stop it infecting them.
Then inside your VM go to device > install guest additions (I think you need this) and reboot it when done.
Finally, open up a folder and go to tools > map network drive and map a drive to:
\\vboxsvr\[share]
i.e.:
\\vboxsvr\Downloads
And it should(!) work.
It only works if you map the drive.
edit: too slow :o
You know I've been doing it my way for so long I didn't even know that option was there. Amazing what your brain can filter out when you're not looking for it. :rolleyes:
Good tip though!
