Few points:
o Pets at home are a bad place to buy fish from, they look pretty in the decorative tanks but are usually in very poor condition. Look for a local Maidenhead Aquatics or similar. Chesterfield acquatics appears to be near you as does Spire Aquatics, might be worth seeing what they are like?
o 28 degrees is a bit high for the temperature and reduces the amount of oxygen the water can hold. Aim for 24 - 26 degrees, however make sure you reduce it down very gradually (over 3 or 4 days) else it may affect the fish.
o Doing a half water change should only be done in extreme circumstances as it stresses out the fish. A 15-20% water change every couple of weeks minimises the impact on the fish.
o You really should have testing kits to tell the ammonia, nitrite and nitrate levels in the tank. Ammonia and Nitrite levels should be zero when introducing new fish and Nitrate should be 20ppm or lower. Ammonia is formed due to adding new fish (due to more fish feces breaking down). Ammonia slowly breaks down into Nitrite which in turn slowly breaks down into nitrate. Nitrate can be reduced via water changes and having live plants in the tank
o Finally for a novice at keeping fish you are buying difficult fish to keep. cichlids, Gouramis and Mollys can be challenging to keep, particularly together. This is the benefit of going to a proper fish shop, they will tell you what will/won't work. I suggest when you buy more fish consider something from the Tetra family (neons, black neons, etc), Harlequins or Danios.
