to overclock you use the best cooling method available to you
i have used air for the 860
hope this is ok with you
the reason i bench on water is because if i just said the chip could do 4ghz [or whatever the max on air is]
then you wouldnt see how far they push
i have already posted what air temps are for the 750
and i will post air results tonight
but to be honest, air cooling is boring
i like taking hardware to its limits and seeing what it can do
we all know an i7 920 sits at around 75'c under load at 4GHz on most of the decent air coolers
knock around 5'c off for the 860
knock around 10'c off for the 750
you really dont need to see air results
if i was benching on LN2 or SS then i could understand![]()
I can understand your pain
HOWEVER, most of us don't work where you do or have the dosh to play with such mega-stuff!!
So, for the paupies amongst us PLEASE put aside your frustrations!
[big enough creep, ya reckon??
