The rolleyes was at myself. Please consider that an apology. The advice was freely given and intended to be helpful.
I take it my Swiftech Block from the Apex Kit won't fit the GD65?
I'm afraid not. The S1156 sits exactly mid-way between the spacing for S775 and S1366. I'm using an EK Supreme which has a slot cut in each corner. At the inside edge of the slot you get S775, S1366 is the outside edge of the slot and somewhere in the middle is S1156. When I first saw the EK Rev II plate I thought Eddie had excelled himself at some cheapskate way of not having to drill a precise hole, but now I appreciate the smart thinking behind it.
It's pretty incredible really.
Is the H50 easy to install? And does your cpu clock over 4Ghz with it?
I'd imagine that 4Ghz is easily doable with one of these![]()
So you will need good cooling.]
By all means, shell out £60 on an H50 and another £20 on a pair of Akasa Apaches, but if it turns out that my CPU is normal, and not a hot-running oddity, and you can't control your temperatures properly, please don't say you weren't warned.
WJA you've made your point...
I paid £50 for the H50 and zero for the fans, you're grossly exaggerating the cost of one of these systems to make custom water appear the better option, I've seen you do this a few times. You don't like the H50, we get it![]()
I would say if you are after 4Ghz ish then a H50 is top notch.
And that doesn't include £1 for 4 extra 3mm screws to attach the second fan
or the £5 Corsair will charge you for postage on a S1156 adapter plate
You've bought yours now, I understand that. And you have to live with it, but it doesn't mean you have to encourage others to make the same mistake.
I know that the internet is a big place and we all like to be 'in' but I can answer yes to all of those questions above with the exception of the S1156 plate amd I'm specifically saying DON'T DO IT.
