Wait on a Megahalems adapter plate and get one of those.
Yer that seems the one to get with 2 fans but which apache or or noctua fans ?
Not really required.
Corsair plate is £3 if we're being pedantic
I'm struggling to see why it is a mistake it is one if not the best CPU cooler on the market before full water system, you do have a terrible attitude problem sometimes.
I already know my chip requires silly low volts for 3.5Ghz I'm not expecting a jump from 1.15v all the way to 1.4v tbh and I'll be surprised if I do
	For the record, I've seen Zalman £30 towers running these chips at 4Ghz albeit low voltage but then the silicon on average is looking better than yours
I'd like to see you run your 4Ghz on the Prolima when the 1156 is out, I'm dieing to see what that baby can do![]()
	I am running a 3.3GHz with 1.1 volts according to CPU-z and set to 1.08 in the bios, stable on prime for about 2 hours amd I reckon I could get a bit more while keeping temps below 75 on stock cooling. Going to play about it later.
That's very good indeed.
Temperatures on the stock cooler?
When you say 3.3GHz - what's the make-up on that? ie. 157x21 or what?
Thats similar to what I'm experiencing, your chip sounds very similar, what is the FPO (it's on the box)
	That is using 165x20, I cant use 21 for some reason... temps are around 70-75. I might just be able to knock off some voltage but I dont think it will be prime stable.
That sounds mentally high for 1.1V. If you can't use Turbo Mode you must have disabled EIST and C1E in the BIOS somehow.
Got a link to these uber-wafers?
