Sorry for the late reply, just to confirm the Civic I had with an LSD was because I fitted an Integra Sir-G gearbox after the standard one started to rattle from the extra torque due to the turbo I had fitted.
I have a 2005 Saab 9-5 Aero now which from the tests I did on the ramp yesterday it seems to have an LSD. With the car in the air and in gear I turned one wheel and the other wheel turned too and couldn't be stopped. Although I can't find any info on google about them having LSD.
Best explanation, even if it is a bit old. Skip to 1min 50.
That explains a standard differential, an LSD works the same but the gear in the middle will only rotate up to a maximum speed so there is a limit in the difference between the speeds of the 2 wheels turning.
So did I, that low power FWD cars that are A-B mobiles driven by old grannies do not require an LSD as they will not be ragged about at their limit on the track/road.
And since the majority (>75%?) of FWD cars fall into the above segment my statement that most FWD cars do not need an LSD stands and is correct.
The Ti's LSD made a huge difference on the first Yorkshire meet - I got a bit over-eager on a hairpin and it didn't half cut the understeer! Smiles all round
RWD doesnt have huge issues with traction. But FWD the difference is massibe, you only have to drive a Civic Type R and a Dc5 to see how much more grip there is, the Civics just light up the tyres as pretty low throttle openings.
You have to be gunning a RWD to get wheelspin IMO.
This. I rarely find the lack of LSD in my car a problem (Despite BMW's insistence that DSC is an electronic LSD I doubt very much it is as good as a proper one) and I need a wet road or to be driving like my trousers are on fire to get wheelspin really. It just never happens in normal driving.
