HTML on Flash
OP
11 Jul 2004
Neptune
That's fine! I'll do that!..but not sure how to get the HTML sitting on the flash.
I'm happy creating the swf and the HTML site - it's just overlaying the HTML over the Flash that I'm struggling with! :)
7 Mar 2005
LU7
You could experiment and see what happens if you link to the Flash. It might just be at the top of your HTML though. You could try setting the Flash as your background. Not sure if HTML would allow that.
OP
11 Jul 2004
Neptune
All you need to do to be able to lay HTML over flash is add the following parameter to your <object> declaration (if you don't flash will show above regardless of z-indexes):
Code:
<param name="wmode" value="transparent">
Will have a play with that. Thanks.
I've tried in Dreamweaver and it doesn't allow a background 'image' to use swf.
OP
11 Jul 2004
Neptune
Going to have a play today.
Was suggested this on another forum:
"Position your SWF on the top left corner of your page with absolute positioning. Then make a wrapper DIV for everything else which is also positioned over the SWF element."
