Program to display folder sizes
6 May 2009
What simple program/windows XP addon is there to display folder sizes next to folders?
Something that would display the size in the 'size' details column instead of being blank would be great
Folder size (the one linked above) works great but does take a bit of time to calculate the size of large folders
yep, thanks guys. Installed folder size and am using it now. You are right, it does take a bit of time to calculate, cant say it can be healthy on our citrix server load but do need to sort out the massive tsprofiles we (our users) have
treesize pro is also another one - older versions (5+ years old) are very lightweight - not sure what the newer versions are like.
foldersize is awesome, but I don't think it works with Vista :(
yep, just found 2 archive.pst files in people profiles for some reason that were 250mb each. No wonder it takes ages for some people to login, also a mass of temp files and people leaving stuff on desktop instead of saving on the network :rolleyes:
jdiskreport is a very handy tool, will probably help you out further..
it requires java, but it's worth it..
thanks. When you scan a file tree is it possible to display an address bar? I want to put in locations of TSProfiles etc on our network.
Through microsoft windows network you cannot press ok or browse through folders
