New System for Windows 7
28 Dec 2002
South Coast
Looking at giving my system an upgrade, but not wanting to break the bank.
Currently running:
Intel Q6600 (original one)
4GB RAM
Nvidia 9800GT
Gigabyte GA-965P-DS-3 V1
SATA drives / DVD-RW
Noctua HSF
Antec 300 case.
Vista x64 (Windows 7 RC x64 at the mo)
I'm starting to looking at these i5/i7 machines and not sure what's the best route.
I play GTA a little bit and do a bit of VMWare etc.
Wondering about an SLI motherboard and then getting another 9800GT 2nd hand.
Windows 7 Pro x64 on order.
Budget I reckon is circa £300-£400
You still have a pretty powerful machine the only i would think of changing on that budget is the graphics card maybe a new harddrive if you bought your current drive at the same time as your cpu etc. Do you overclock the cpu?
For the money, and considering the fairly high spec you already have, I would agree with DIABLO, spend the dosh on a new VGA card and maybe an SSD for windows to live on.
If your not already, OC that Q6600, should be good for 3ghz easily ;)
Haven't o/c the q6600 as it never was cool enough. I was going to get another 4gb ram, but thought with the new DDR3 it wouldn't be a good move.
You got a noctua heatsink yet you're at stock speeds? If i was you i would investigate why your cpu runs to hot with a noctua cooler for you to overclock.
Hotter than I wanted, but far cooler than my Arctic 7 HSF
I'll look into it again
Not running any temp software with Windows 7 atm
I used to be ok with overclocking, but spend more time with proliant servers to bother at home etc.
What would be a bigger upgrade, a move to the I5 or an SLI based system?
Still toying with the upgrade idea and although I don't normally do finance, the 0% at OCUK is tempting..
I could easily spend £700 that route!
