 - 17 Sep 2009
 - UK
I once blew my PSU from OC'ing my e6600. The chip was fine tho - i love you e6600
  budget stuff for other people is fine, but never for myself.
  even tested it once on 1GHz and it was fine. Had to worsen the timings for the 1GHz test though... on 900 it was still on 4-4-4-12.  Excellent.
 Pulled it out and there were 10 pins burnt.
).It's all about the cooling. Which can degrade over time as fans get dusty or even fail. As long as you get the heat away, they generally will keep working fine.
I've burnt out a gfx card and a processor from overvolting and not cooling enough.
Electromigration can kill even a well cooled chip, although it can take time. Ask anyone who fed too much voltage into a Northwood P4...
yup, all my CPU's have gradually lost speed to the point they no longer run at stock. I put it down to Electromigration. Dunno if that is the case though.
I can quite honestly say that has never happened to me.
how many boards have you voltage modded to run them? (like sending 2.15volts through a 1.70volt cpu?)![]()
 ...the answer is none
