Where is Chuck Norris? (Google Easter Egg)
3 Feb 2009
Brighton, UK.
Did you type "find elmer fudd" or just "elmer fudd" If it is the latter you fail :D
You mean former, the "latter" is the correct one
You also have to spell Elmur with a U.
Fine, heres a step by step guide:
1. Go to google.co.uk
2. Type in Elmur Fudd spelt exactly like that.
3. Press "I'm Fealing Lucky"
27 Dec 2005
Bristol
3 Feb 2009
Brighton, UK.
29 Apr 2007
London
You typed this:
Unless I missunderstand you, you said he failed if he typed the latter, but the latter in that sentance is correct, "find elmer fudd" is the former, "elmer fudd" is the latter.
No, because the latter takes you to wikipedia and the former takes you to the translate page. :rolleyes:
