I get Wikipedia as the first link. Bomb fail.
Did you type "find elmer fudd" or just "elmer fudd" If it is the latter you failI get Wikipedia as the first link. Bomb fail.
Did you type "find elmer fudd" or just "elmer fudd" If it is the latter you fail![]()
Do the same but type in Elmur Fudd.
Elmer Fudd is not a google bomb, it's a "translation" of google.
Thread contains too much fail.
No, just most people don't seem to be capable of reading.
Elmer Thudd is a Google translation thingmebob, there's also a Klingon version and a few others. http://www.google.com/intl/xx-klingon/
No, what I said was right.You mean former, the "latter" is the correct one
You also have to spell Elmur with a U.
Fine, heres a step by step guide:
1. Go to google.co.uk
2. Type in Elmur Fudd spelt exactly like that.
3. Press "I'm Fealing Lucky"
No, because the latter takes you to wikipedia and the former takes you to the translate page.You typed this:
Unless I missunderstand you, you said he failed if he typed the latter, but the latter in that sentance is correct, "find elmer fudd" is the former, "elmer fudd" is the latter.
It is a google bomb.
