Thierry Henry only has 4 1/2 fingers on his left hand, he trapped a finger in the door of a Clio when doing the Renault adverts years ago.
Gold is used as a thin film in astronauts visors because gold reflects heat better than any other metal.
how about - the idea that people use only 10% of their brain is nonsense. everybody uses 100% of their brain otherwise it wouldn't be there. some use it better than others
A simple look at brain scans will show us that the brain modulates dramatically from one moment to the next in regards to its activity and usage. Here it is then, on the screen of Functional MRI machines and Pet scans, incontrovertible evidence that we do not use all of our brain all of the time.
The myth is that 90% of our brain 'potential' is permanently unused, which is meant to suggest the capacity for telekinesis or telepathy or whatever. Brain scans clearly show all of the brain is used, just not at the same time.
I think maybe you switched the names mistakenly if you were going for the 'probability of 0' as opposed to the 'probability of 1' example.Of course there is? Take a random variable X with a probaility density function supported between a and b , the P(X>b+1) =0.
And no matter how infinite time is if the P(X>b+1) = 0 . X will never be greater than b+1.
EDIT: Simple example
John is born on the 01,01,1970 and Bob is bornon the 01,01,1971, Bob and John have infinite life spans. What's the probability that John is older than Bob?
Basically my point here is that no event is technically impossible on an infinite timescale, just at best extremely, extremely, extremely unlikely. Your equation works fine in the confines of a maths class chalkboard, just not really outside it.
