i5 you said, i5 you get..
Nah its not, unless your going for some sweet benchmarks, i5 is all you need, and my suggestion is excellent value for the performance your getting, the case is mint and not a budget part in sight.
Cooler added.
Yeah, but not when it comes to gaming. The i5 750 stands up to the i7 920 and even wins in some benchmarks. Considering that it's much cheaper it makes more sense going for the i5.An i7 920 is a lot better than an i5 750 to be honest.
Personally i like kyle's setup as you are getting x58 v p55, i7 v i5, 6gb ram v 4gb ram for not much more money.
Btw for those considering a 5850 vs a 5870 - it's not just the memory and GPU clocks which are different: there are fewer shaders and texture units too.
.I'm speccing up a similar system with a budget of around a grand and think the 920 is the way to go, though going to need an after market cooler to do better than the i5.
The i5 turbo is much better than the 920 so at stock speeds the 920 would lose out a lot.
I've just completed a new build and looking for a new card to upgrade to, my trusty old 1900XT is now beginning to struggle quite a lot lol, can the 5850 be clocked easily to achieve 5870 performance?
As I understand it both cards are physically identical just different clock setting on the GPU and RAM.
Stu
Haha yeah, I just figured there was a post on the previous page which was thinking that it was just a down-clocked cardIndeed, most of us have know this quite a while now.
off topic: you're not keen on the i5 750 - if you were spending £300-400 on the machine instead (CPU/RAM/motherboard) would you still not consider it? I'm thinking about doing this myself and would like your opinion.
not its not off topic....
anyways thx Kyle for you spec but as someone said if ur not overclocking go for i5...imnot going to overclock it for sure...
speaking of Ram... i would love to have 6gb instead of 4gb
PCI speeds- doesnt matter i guess i will only use 1 card...
And i need a modular PSU i am noob, it will be my first build lol
dont know what to do![]()
