Kingston HyperX PC2-8500
Caporegime
26 Aug 2003
Leafy Cheshire
Quick question;
Does anyone happen to know the default voltage for this stuff, short of me pulling the machine apart to get to it to take a look (not simple, its in a non-railed rackmount case).
I'm sure its being quite catastrophically undervolted at the moment (and I'm getting memory related BSODs), at 1.8v. I've got a feeling it should be 2.0v?
19 Apr 2003
Awesome, timing is tight, so 2.2v it is :)
I have the same memory and have found that i can run it at 2.0V @ 1066 5-5-5-15 (2.2v is the default voltage for these timings but sometimes not necessary with a bit of tweaking).
Some forum members have managed to get these settings stable at ~1.8v/1.9v - but your setup, like mine, will BSOD at such low voltages.
Once you've established it's stable at 2.2v you may want to consider testing it at a lower voltage as they do run warm at 2.2v. This isn't a problem, but if you can get your memory stable using lower voltages - so much the better.
22 Apr 2006
Port Talbot
yep running mine 2.1V (8Gb (4 x 2GB) ) at 5-5-5-15 - superb memory for the price I would recommend though that if you're using all 4 slots definitely push the Northbridge voltage up a little
