Hi guys,
As you may or may not remember, I passed my MOT about a month and a half ago needing just a replacement number plate light @ 29p
(car in sig)
Anyway, I got a couple of advisories and am planning on sorting/getting them sorted at some point in the not too distant future. They are as follows:
1) n/s and o/s Front constant velocity joint gaiter deteriorated
2) Front brakes only just met the front brake imbalance requirments. It would appear that the braking system requires adjustment or repair.
So I was wondering - does anyone know how much I should be expecting to pay for each of these, so I get a ballpark figure for when I start ringing around? Also, I'm not afraid to get my hands dirty, but don't have a ramp available (and my Haynes is currently in my car, out in the cold) so presumably I won't be able to DIY the CV joint gaiters? At this stage I don't know what that involves so it may be a silly question.
Any suggestions/tips/insults (I'm waiting, JanesyB
)/whatever also welcome.
Cheers
(car in sig)Anyway, I got a couple of advisories and am planning on sorting/getting them sorted at some point in the not too distant future. They are as follows:
)/whatever also welcome.Cheers
If you have no room to work, no real desire to do it and no tools then it's probably a job for a local garage.
). So I was hoping for a bit of advice on how to tell if it's on its way out, if anyone has any? I've checked the belt and surroundings for any indication of if it's been changed (e.g. date of manufacture) but can't find anything. It's manufactured by Goodyear if that means anything to anyone (for example, are 106s stock-fitted with Goodyear timing belts?)
