Prototype/jQuery plugin issue
25 Oct 2004
Sunny Torbaydos
Hiya,
I currently work on a site which uses the prototype framework but require a plugin that can be used to allow only part of an unordered list to be visible until a user clicks to view more.
I've been using Collapzor jQuery plugin but turns out that has been causing major issues between the 2 frameworks.
Anyone know of a similar plugin to Collapzor for the Prototype framework ?
8 Oct 2005
Midlands, UK
Hiya,
Have you tried the JQuery noconflict plugin, that sometimes works.
2 Apr 2004
Melbourne
If you are using prototype, use prototype. Don't jQuery to your site just to use one plugin.
I recently inherited a project at work that used mootools, jquery and prototype in various places. Such fun to pick that mess apart.
