***HTC Magic Thread***
You would just buy the handset or get a new contract?
Well if T-Mobile had a phone I fancied then I'd probably do it on contract when mine came up for renewal. If not I'd just buy what I wanted as I did with this Magic.
BTW I restored my nandroid backup to the old cupcake that I was on. My accelerometer works again.. at least I dont have to send it back (phew)!
So you're back to the default phone version of Android? How do you do it exactly? Just copy the files from the nandroid backup folder to the root and do a restore?
MM for £200. doubt you can do better than that. I'm gonna sell mine too.
Wouldnt sell it on MM anyways:p...ive put it up for £250 on another site and have already had a few people contact me about it...might have a guy come down tomorrow to have a look at it...id let it go for £230 if the guy was serious about it.
Yes.
I rebooted using home + power, then selected 'revert to last nandroid backup' in the menu (said something like that).
As it was my latest backup it switched me back to that.
No time to do it at work, will have to do it when I get home :p
What did you have on before btw? differences?
I'm playing with the Hero ROMs atm, quite liking the facebook/twitter integration they've got going on, speed is pretty decent too now.
Which Hero ROM are you using? I tried this one myself but i just couldn't handle how slow it was :(
I'd install a Hero .rom if I could work out how to. There's always about 233 steps that confuse me :(
It's just the same as any other ROM mate :)
Doing it now. A little nervous :D
<edit> so far so good, it all installed OK and have booted up and checked the versions in "about phone". Currently doign a couple of reboots, as instructed (not sure if that is deffo needed but I am following the instuctions to the letter.
BTW anyone still unsure as to creating an EXT pertition to get apps to SD working (auto on Cyan roms if part exists) I used this method using ADB (so no need to boot into Linux live CD etc)
http://forum.xda-developers.com/showthread.php?t=543985
And got:
Code:
performing selected actions...
creating fat32 partition...done
creating ext2 partition...done
creating swap partition...done
adding journaling to /dev/block/mmcblk0p2...done
retrieving current sdcard information...
Model: SD SU04G (sd/mmc)
Disk /dev/block/mmcblk0: 3965MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number  Start   End     Size    Type     File system     Flags
 1      32.3kB  3422MB  3422MB  primary  fat32           lba
 2      3422MB  3933MB  511MB   primary  ext3
 3      3933MB  3965MB  32.2MB  primary  linux-swap(v1)
:D
Thought the Magic supported MPEG-4 video format?
Just copied the latest MW2 trailer to the SD card and it says
'Can not play this video' anybody know why?
It won't play HD based content, needs to be in a supported resolution too so needs to be re-encoded smaller res.
I use mediashow espresso to gpu convert to .mp4 using the iPhone profile, works great.
I was using the same, it wasn't slow all the time, and when it was responsive it was pretty quick, just for some reason it would suddenly lag really badly for a few seconds, has put me off a bit but I like what HTC have done with it, maybe the Moto Blur stuff will be less heavy that looks interesting too
Where and how do i get this Program, is it free ?
Tried the latest 2.9.8a with A2SD last night, almost as fast as CyanogenMod 4.1.11.1.1.1.1 :) Didn't stick with it though and updated to Cyan's 4.1.99 and OMFG is that fast :D, really can't wait for the stable version.
did you have an ext3+swap partition? this speeds things up somewhat!
I did, class 6 card too, when it was ok it was bloody snappy, would just get periods of intense lag or "Loading" at the homescreen.
Just got 4.1.99, and to echo Raz84, wow is it quick.
