Im thinking of getting a flat screen monitor when I finaly replace my 5 year old gaming pc and would like to know If anyone could def recomend 1 screen over the other.
Is there ghosting with either monitor?
Does the 120Hz Realy make that much of a difference for gaming?
Sorry if this is similar to other posts Im just wondering if its worth shelling out the extra cash.
Dell UltraSharp 2209WA 22" Widescreen LCD Monitor [2209WA]
£186.99 inc VAT
With a non-glossy coating and impressive resolution, contrast, luminance and response times, the affordable Dell UltraSharp 2209WA delivers sharp, detailed images, saturated color and breathtaking multimedia performance.
- Screen Size: 22" e-IPS Widescreen
- Resolution: 1680x1050
- Contrast Ratio: 3000:1
- Brightness: 300cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 511.77mm x 361.91mm x 184.12mm
- Weight: 7.93kg
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line
Samsung SM2233RZ 22" 120Hz 3D Widescreen LCD Monitor [LS22CMFKFV/EN]
£258.99 inc VAT
The Samsung 2233RZ monitor boasts the refined, streamlined and unique design, in addition to its top-class performance, that consumers have come to expect from Samsung. The display is housed in a thin, glossy black bezel that is a stylish accent to any environment and provides a compelling 3D experience with incredible picture quality. Unlike many other widescreen monitors, the Samsung 2233RZ displays 5:4 and 4:3 images at accurate aspect ratios without enlargement or distortion.
- Screen Size: 22" Widescreen
- Contrast Ratio: 20000:1
- Response Time: 5ms (2D) / 3ms (3D)
- Viewing Angles (H/V): 170°/160°
- Inputs: 1x DVI-D
- VESA Compliant
- Dimensions: 516.8mm x 421.3mm x 208.7mm
- Weight: 5.5kg
- Warranty: 3 Years On-Site
£186.99 inc VAT
- Weight: 7.93kg
£258.99 inc VAT
- Inputs: 1x DVI-D
- VESA Compliant
- Weight: 5.5kg
