CoolerMaster HAF932 Thread
BUMP!
Few pics from my HAF.
I think I might do the mod for dust filters, quite a lot of dust build up in a few days.
Pfft. They were showing up before, forums don't seem to like google albums photos.
EDIT: Ok fixed. Sorry for the bad picture quality lol, make the case look ugly.
Just a few questions;
  1. Does the side mesh leak out much noise? as my pc sits right next to me on the desk next to my mousepad
  2. what kind of air flow do people use? does this include sidepanel and roof fan? on push or pull?
  3. Can you use screws on the 5.25" bays? (seen someone else post about this but that was it, no conclusion)
For around £100 I might just get it anyway.
Thanks.
1. About the same as a case with a big window in the side, the stock fans are virtually silent so the louded thing in your base will probably be your HD or CPU fan.
2. It comes with 220mm front, side and top fan of which the front fan is red LED and a 140mm rear fan.
3. No you can't, but the retention mechanism works great for optical drives.
Only 2 things i don't like about the case is the very bright power and HD activety LED's which i have to cover at night and i wish the inside was painted.
Thanks diablo. Question 2 was more concerned about airflow, what fans people have on push and which ones on pull. Whether they have their roof fans on exhaust or intake. And also whether they used the side panel fan as I read a few posts concerning it interfering with airflow, but by totally removing the fan it also messed with the airflow. Mind boggling stuff lol.
Thanks.
Top exhaust, back exhaust, side and front intake. There is'nt a lot of air flow from the front for the side fan to mess up as the harddrive cage retricts flow from the front fan quite a bit so the front fan only really cools the harddrives so you need the side fan to get good airflow plus i like that the fan blows directly onto the graphics card and onto the chipset.
Thanks again diablo. Waiting on it arriving today or tomorrow.
