2x8800GTS 640MB In Sli = What single card solution?
Theres a couple more triple A titles coming out that use physx atleast as much as batman - possibly more...
Personally I think it added nicely to the atmosphere in batman - even tho most of the effects used could have been done fairly well on a CPU only physics lib... except maybe some of the cloth workload in some sections.
PhysX made the frame rate choppy and uncomfortable even on the 'Normal' setting in Batman; that was with a GTX260 @ 1920x1200, max settings. It's just not really acceptable for a few bits of fluttering paper. Installed a 5850 yesterday and won't be looking back.
No problems with framerate here - 2048x res, everything including physx on max, lots of AA... fraps showed it above 50fps most of the time - generally hard pegged against the limit.
The only time I saw problems was if I stayed in those "old" sections with the aqeducts/brick towers for too long (more than 20-30 minutes) - only really noticed it when I went back to do old puzzles - think it was due to the physx falling rubble not being cleared properly and building up a "backlog" after awhile.
EDIT: Oh just realised thats due to the 190 series drivers - I put on to test mid way through playing - I should go back to the 186.18s again - was no slowdown at all with those.
Yeah the games need to run at about 100+ frames before you can use PhysX, as the cards take about a 30 frame hit with it on, so be no good in a game like Crysis, as if you can't break 50 in that with no PhysX, then when you turn it on, you're gona be down to 20. :p
So you are are running a X800XL and just ordered a 5870? Thanks for your unbiased opinion. You don't need to justify your purchase to me my lad, just the credit card company.
Considering you completely missed the other 2 PC's in his sig running nVidia cards, I suggest you go for a 5800 series card. Obviously your eyes do not pick up details, so the little value PhysX brings would be wasted on you :p
I think those numbers are slightly exagerated :P
But this is one reason I like SLI + PhysX - a lot of the time neither card is running above 70% load so theres plenty of space to run physx work before it starts to touch the framerate at all.
Theres a review posted in here somewhere, shows the 275/285 running Mirrors Edge with and without PhsyX, with PhsyX on, the 285 dropped about 26 frames, the 275 dropped about 30, now thats some hit for some waving flags. :eek:
Bare in mind that some of that hit isn't the physx processing itself but drawing the visual component of the extra effects.
Or you could do what I have just done. Have a 5850 running at 950/1250 with a gtx260 for the physx.
Best of both worlds. ;):D
Batman with the physx is fine, runs really smooth and looks stunning, dunno what people are going on about up there tbh :rolleyes:
I don't own a 5870, my main rig has a 260, and I actually picked up another for 260 SLi, so well done
Waiting for a 5870 2gb for 6 screens.
Enjoy PhysX :cool:
have nvidia stopped people running an ati and nvdia GPU , from a driver version number ?
Calling me a liar then :rolleyes:
It ran like arse, shouldn't do, no idea why, end of :)
Not worth the hassle given how much of a total marketing gimmick PhysX is anyway.
And I'm supposed prefer Nvidia...
if your staying green then woudl say hold out for new gen card from them later this year/early next year. bit pointless buying old tech of the 2x series now imo
It runs like arse, shouldn't do, no idea why, end of :)
And I'm supposed to like Nvidia...
Grow up, I didnt even quote you (in my previous post, lol):P
No, you inferred. Granted it could have been a driver issue and I didn't look into sorting it out, but that just shows how worthless I felt the PhysX effects were.
Regardless, as for the original question, two G80 core 8800GTSs should be around as fast as a GTX260, given that a 9800GX2 which ran two G92 core 8800GTSs was a bit higher than that.
Calling me a liar then?
:rolleyes:
Awesome Thread!
