Prolimatech mega-shadow
I would say that it is plated, not painted!
I seen this on XS a while ago, looks really wicked I thought.
Damn it, i can see myself buying this if it becomes available over here :eek:
but, it'll be more expensive than the original...... i dont think that Nickel plating makes much difference, it's so thin plus it's a metal coating anyway.
Yep, nickel plated, same with the TRUE black, makes no difference to cooling from the standard version, but certainly looks great.
I wish that I had bought the TRUE Black instead of the normal TRUE, as the Black edition would go much better with my case..
I opted for the back one myself as i couldnt find the standard one anywhere at the time, certainly does look great and the extra wire clips were handy for running push/pull.
Is there any news on when the black megahalem or mega shadow is going to arrive in the uk? I might to this way rather than h50.
