OK I got the UPS working. I just needed to turn it off and leave it off from the wall for 30 mins. Then Hold in the test button for 10 seconds to reset it.
Installed the addin Grid Junction
All is good now.
Now for the BIG question.
I copied some MUSIC and VIDEOS over to the server via USB external drive.
I logged on using remote desktop and copied direct from USB drive to
D:\shares\Music
D:\shares\Videos
Now having read up on it people have said this is not the correct way and it should be avoided.While others have said that they have done this without issue's.
How do I know if everything is OK?
Apparantly someone said to check:
Well I have checked and none of the files are 4KB in size when I look in my D:\shares\Videos folder for example.
Is this pre landing Zone stuff? I know that this was scrapped in PP1.
Should I be worried?
Everything seems to be running okand balancing well. I have oodles of space on my SYS drive left.
Could anyone check the file size in the D:\shares\Sharename areas please?
I want to get this right and its all so damn confusing.
If push comes to shove then I suppose I can copy the data from the unc paths shares to USB drive again.Delete all the data in the shares and in D:\shares\Sharename and copy back directly through the UNC path...
Please help I'm a WHS noob![]()
As we discussed on the other thread, copying directly is a big no-no for the tombstones. And should always be done using the UNC path so these don't get broken for drive extender/duplication.
One important thing to remember is that the DE tombstones will not report their true size, but the size of the file they are pointing to. All tombstones are 4k, but will always report in Windows the size oif the file they are linking to. To prove it just try backing up your D:\ drive directly - with the default MS backup program and you'll soon see that they are very small files and not your real data!
The main thing is you can see and use your data, so you know it's there. I would live with that.
But if this is going to eat away at you, I'd delete the existing files from the UNC path and restore from your other drive.
Touch wood.Depending on how many machine you have, ESET (Nod32) do a very nice package that covers your server and 4 or 5 other machines - I'm saving up to buy it as we speak!
Remote access is very cool.
It get's even cooler when you use something like WHIST (check the add-ins at www.wegotserved.co.uk)![]()
Easy,
Advanced Admin Console beta can be grabbed from here http://www.home-server-addins.com/downloads
The authors new site
Gonna try out PS3 Media Server tonite, only got my ps3 yesterday and was getting loads of DLNA errors when trying to connect. Looking at putting my dvd collection on my home server.
Glad to hear you re-copied over your files btw![]()
I used a cheap noname SIL3114 based card with no problems for a while.
Could people post a screen shot of their Console with WHS Disk Management addin installed please.
I would like to compare how the data is stored over your disks compared to mine.
Thanks
