Growing Chillies
Status
Not open for further replies.
OP
13 Jan 2003
I can't tell between the species (especially the close ones) until the chillies appear :(
I have pencilled in Chilli Cheesy bread for friday if the chillies ripen, or alternatively as it;s only 8 days to my birthday I may just hold off and let them ripen completely. The Nagas are starting to look angry, bright orange with some redness..
OP
13 Jan 2003
Photo just now - the strong light (400W Sodium HPS) is making them slightly less red than they are under a normal bulb but they're getting angrier by the hour:
OP
13 Jan 2003
Chillis Galore is a good site with an active mature forum with both professional and first time growers alike from all parts of the world.
The majority of chillies are a simple case of germinate then pot, place in the right spot and then just water/feed as needed. They look after themselves pretty much.
You can get almost cold peppers and chillies such as NuMex variety (specifically grown for flavour not heat and only 800 SHU, Jalapenos are 8-20K) which will grow as a small plant in a pot on the kitchen window.
14 Feb 2007
I've been reading this threat but havn't posted at all.
Should I cut back my chilli plant for the winter? If so how should I do it.
This is my Office Scotch bonet. I have another at home in the conservatory. Don't think I'll cut back my office plant as its still prodcuing Flowers and Chillis.
The drying Process in a sunny window
And the Finsihed Product (HOT)
OP
13 Jan 2003
Awesome bonnets! If you have air conditioned office windows then the dehumidification helps with the drying process too.
I will cut the nagas back once they've got through the fruiting and had time to store some nutrients, so probably around the start of November. At which point I'll cut the tops back to the base stem and plonk them on the window which should put them into a winter mood (cold and reduction in light).
The some experts often cut the rootball back too and place them into a smaller pot. The effect is to reduce the water requirements and to a certain degree change the soil when repotted in spring.
Personally I'm going to leave the roots as it will need a large enough pot to insulate and keep warm. I'll also put a clear plastic bag over the top to reduce cold draughts etc.
14 Feb 2007
Cheers. The plant loves it there. South facing Window and a constant 23 Degrees with the aircon.
11 Sep 2009
France, Alsace
Is the winter pruning back a must? I've got mine in my room on the window sill but the temps in there are always quite warm as the boiler sits underneath. Is this something that has to be done for the flowering cycle or can you plough on through?
The above looks mint for an office plant! Is that just watering? Or do you feed as well?
14 Feb 2007
Just water on Mondays, Wednesdays and Fridays. I've not given it any feed for ages. I'm always foretting to bring it in with me. Last week i though it had fisnished for the season, but its covered in flower buds again now.
Do Scotch bonet go red? I've left a yellow on the plant for weeks and its not turned.
OP
13 Jan 2003
I have decided that tomorrow will be Chilli Harvest Day!
Activities I have planned:
1) Brew beer in celebration!
2) Make cheesy Chilli Bread using a fresh Dorset.
3) Deseed chillies and dry seeds for next year.
4) Force dry chillies to make chilli powder.
5) Prepare plants for over wintering.
Only thing is the plant has gone nuts and has just trebled it's chilli output but I need to get the plants ready for winter (and a house inspection) :(
2 Jul 2004
Stevenage
Today's harvest, the alleged Antillais Caribbean at the top, a few Cayenne Peppers, a couple of Super Chillies, 4 Scotch Bonnet and a few Orange Habs bottom right.
I still have all the plants in the greenhouse whilst the weather stays mild, I have had to put the heater on 4 or 5 times at night so far when the temperature threatened to drop below 5 C.
I may chance another week keeping the plants in the greenhouse before I bring the plants home that I am going to over-winter.
OP
13 Jan 2003
Ok, I missed friday's harvest date - will be doing this tomorrow! I just want to leave them on the plants as long as possible so that the seeds are jammed packed with energy.
I've noted a little droop due to the cold nights as the house heating isn't on yet.
I have also planned the beer too but that's a separate thread.
18 Jan 2007
Edinburgh
I thought my chillis were starting to slow down or even die and then i noticed this today. I have 1 red chilli on each of my cayenne pepper plants.
These were green 2 days ago when i watered them, they colour very fast :confused:
Status
