Aerocool cases.
15 Nov 2008
Scotland / Blairgowrie
Just noticed aerocool have cases! Just wanna ask anyone who has one.
Are they good to work with? they are pretty cheap of ebay and they look a reasonable size. But they also look fiddly. To much around them.
Heres what i think of some of the more common ones.
Dunno who designed that but they must have been on some sort of drugs...
Looks at decent case but it..to flash for my likeing, will do for somebody whos into gaming and likes a cool looking case :D
the 3 buttons. Stop, stops the fans completely. Cruise sets your fans to 50% speed. Turbo sets them to full speed. I really like that idea!
this... 40cm fan what produces 250CFM...i wouldnt like that to be sitting beside me when gaming, it will have control over the mouse! Also it probly would sound like a jet taking off...from a foot away.
Heres some more aerocool cases.
What do you think of these cases? I wanna know if there good to work with. Might consider one for my next build.
I've just fought long and hard to steer a friend of mine away from these and he's a teacher of all people, he should know better.
They've definately got the "1337" market covered that's for sure.
When we drove to our local PC store to check them out in person they were tacky, flimsy, rattly, weak, gaudy and all round awful.
I'm not a fan.
I have the aerocool coolview case with inverted motherboard tray :D
Nice case best one i have had only few little problems but i paid 50 for it new and i think it's good deal.
By the way, 250cfm from a fan 400mm across is nothing special.
Not much RPM needed on a fan that size, won't be much pressure just flow, it can't move your mouse unless you stick a sail on it.
Isn't it obvious already from pics that Aerocrap's slogan is bling bling ping pong trash trash.
And no pressure means no airflow when there's any kind impedance...
And these sidefans just happen to be cramming air toward dead end.
I know, I'll spend hundreds of pounds on components, then stick them in a cheap £20 box. Then again maybe not, each to their own I guess. While one or two don't look too bad, some of them have more plastic parts than I've seen in a toy shop.
