made a lil vid demo'ing what to do if your engine gets shot out, this often happens in multiplayer.
As soon as the engine cuts pull the right thumbstick DOWN to get as much air going though the rotors on the way down, then when close to the ground apply full power and you should rapidly slow your descent and be able to make a safe landing.
Engine gets cut at the 5 second mark.
obviously the vid is a textbook situation, but this works at any height and can work even if your over trees, you just need to slow your descent down enough not to explode on impact
