ive ordered my win7 but noticed after ordering i forgot to choose 64bit, so ive ordered 32bit.
im currently using vista premium 64bit.
rig in sig.
thanks Ali
rig in sig.
thanks Ali
I'm unsure why you would revert to 32bit if you've been running 64bit Vista.
If you can get hold of a 64-bit disc you should be able to use your 32-bit key with it.
this is correct. the license-keys are architecture inspecific.
Im pretty sure both versions are on the disk.
Trying to sound clever doesn't work when you use a word that doesn't exist such as "inspecific."
I apologise, I missed a hyphen. Do you want a cookie now?
i think the mistake was that you should have used unspecific.
are there noticable differences between 32 and 64 bit?
Memory limitation of 4GB.
well... shh i got a friend to order it for me! he did try to was told its too late.
